Mine was perfect. The stock headlight housings have a movable cutoff shield for the high beams (Bi-Halogen). They have instructions on their site if you need them IIRC.
Okay just installed them. Didn't realize the factory headlights had the cutoff shield to accomplish the high/low action, thought it was the bulbs that needed it. So that part is fine.
Took me a few mins to figure out the wiring. The extra pigtail tossed in threw me off the most. A simple label saying test leads would have saved some unnecessary confusion. I would have been better off never reading the directions on their site. They sucked. I called TRS, they sent me another set of newer instructions, and they were slightly better but stopped half way. Since I've got knowledge of doing past HIDs and knowing how relays actually work I was able to figure it out on my own, but I view these types of mods like even my wife should be able to do it following a few simple instructions. The TRS instructions were garbage and I can easily see people getting screwed up and frustrated doing it if they didn't have any past experience.
The variability on the bulbs suck too. My drivers side one was loose as chit, and the passenger side one was so tight I almost couldn't get it twisted in. My factory bulbs both twisted out with the same tension, so that tells me it's probably not the housings.
And lastly, the female connectors with the male pins to plug the factory plug into to trigger the relays was terrible. Took me longer to get those little pins lined up than to do the whole install. They should spend the extra 5 cents to use the proper connector with guides that line up with the factory connector, rather than some universal one that kinda-sorta fits after 10 minutes trying to line the pins up. Good thing you only need to hook one up with the relay kit, I never could get the passenger side plugged in.
All in all, they look great, the balasts and parts feel like high quality stuff, but their looming skills are on a kindergarden level, half the shrink tubing wasn't fully shrank, and their instructions are so bad I see why they don't include them in the box. For all their trash talking of ebay products, they've got some work to do themselves for easy stuff that they shouldn't be screwing up.
