Not A clue as to what the readings should be but using A VOM set to ohms
will, attached to the connector pins give various readings when the throttle is open and closed.
Maybe not alot of help, sorry
really the only way to test a TPS is to hook up your leads on OHMS and turn the butterfly through all the ranges. If you ever get an OL -- you need a new sensor
