dont slow down
- December 1, 2014
- Elizabeth City NC
- 2022 Explorer Limited
I was just at the Ford dealer having a few warranty items fixed and told them about a slight "clunk" noise coming from the front wheels when I pulled into my driveway. It would happen with the wheels turned to the right as I went up the small bump from the gutter. I read here on the forums that sway bar links have been problems so I asked them to look at it. After a bit they took me out to the shop and showed me the problem. It appears that the CV axle has a bit of play where the splined shaft enters the transmission. TSB 14-0186 instructs to install a metal and nylon washer between the housing and shaft to take up the play. After driving home I can confirm the clunk is now gone from the right wheel but also made it very apparent the left side is doing it to. So I will have to take it back to have them do the left. I read through the TSB sticky and this one was not in there.
