Other than changing out the front axle for something like a Dana 44, you are likely better off with what you already have (unless huge tires are in the plans).
All the Jeep dudes are begging to get their hands on our 8.8's becasue it is a great axle that can handle up to 37's in most wheeling situations. The front TTB is another story - and I can understand why someone would want to swap that out - but make sure that you go back at least as strong, which would have to be a Dana 44. Early Bronco's are almost a direct swap in due to axle width, but would require a lot of braket and spring mount changes. It's probably easier to just re-drill the hub in the new front axle for your desired bolt pattern.
Almost everything else out there is not as heavy duty as what you already have - unless you go to full width axles out of a 3/4 ton truck (as already suggested).
