Premier, have you corresponded with Josh Adams and seen if you have similar problems? You are the only two that ordered LockRights instead of NoSlips and are the only two with problems..... I cannot help but believe that something about the LockRight isn't right....
....and I concur, did you do the brown wire mod? If no tcase power at all is going to the front, I wouldn't think it would lock, The NoSlip doesn't..... maybe the LockRight does, even while freewheeling????
Does anyone else have a LockRight installed? Maybe the only locker we can put in is the NoSlip???
Something isn't adding up.......
