sn0border88
Master Apprentice
- June 27, 2005
- Souderton, PA
- 1992 XLT
Installed my fuel cell today, running a ford e2000 pump off another ford inline EFI application. I am using a small filter before the pump and the stock one after the pump, going into the stock efi fittings in the drivers wheelwell.
FOr whatever reason it wont run now, I have fuel pressure after the stock filter but thats as far as I had time to check. I removed the stock tank and all associated wires, did the computer depend on something here to run right?
I am using the same power wire from the stock pump on the new one, so thas not an issue. I can hear it run when I turn the key, everything looks like it should work.
There are 2 different sized fittings at the wheel well, I assume the larger one is the pressure line and the smaller is the return?
I can also get it to run in short busts with starter fluid, but its just not getting any fuel. Any ideas?
