- July 14, 1999
- Omao, Kaua’i
- '93 Ranger XLT 4X4
The filter I removed off the truck measures 6.5”.
I haven’t done this for myself in years, so I did read up and watch a video to refresh myself on the details, and there’s a warning to not use a filter that has too short fittings, because you won’t be able to get the disconnect tool on next time you change it.
The new filter looks too short to get the tool on next time.
So I go back to autozone, have them check other brands to see if they might be longer, and none are.
Then I go to Napa, same for the Napa filters.
Then, the guy pulls a filter for a 1995 rather than 1994, and it’s longer!
But he then tells me that I don’t need the disconnect tool on these, they only use the white plastic hairpin clip to keep the lines attached. Says the lines just pull of by hand after the clips are removed!
So now I’m unsure on it all.
I would like to use the made in USA motorcraft filter, but it has short fittings.
The Napa filter has long fittings, but is made in China and I’d rather use the motorcraft because of that if I can.
I’m probably over analyzing this and won’t own the truck by the time it needs another filter, but...
Tell me, what’s the true story here? What filter should I use?
Side note: all brands I checked came with caps on the fittings and new plastic clips, EXCEPT the motorcraft!
