fuel injectors differences | Ford Explorer Forums
denter
enfield, ct.
98 xlt
Does anyone know what is the difference in the white 99 5.0 fuel injectors and the yellow 98 fuel injectors. are they interchangable? Do they have the same resistance ohms?
Look at the numbers...
On the two injectors in question and then use that info to find the flow rates of each one...
You may find they are pretty close to each other...Post the numbers and someone here might have that info as well..
no they will not interchange.
The later model injectors connectors are slightly different. They look like they might work, but do not.
turtle
thank you very much you just saved me a big head ache. Den
