spits
- December 17, 2009
- Titusville, FL
- 1998 Mercury Mountaineer
Thanks for the replies. I wasn't sure how much interest this thread may attract so I didn't want to load it up with what I've done, but, here goes.Okay we may need more info, rather than "similar to what I'm currently experiencing", exactly what is the issue? Multiple different fuel system components could cause a no-start. For example does it not start, every time you try? Do you ever hear the fuel pump come on when the key is turned to run position, right before starting it?
What have you checked so far? After turning key to run position, without trying to start it, have you measured fuel pressure or at least depressed the schrader valve to see if any fuel squirts out? If none does, then I would have a helper turn the key to run, while you are holding open the valve to see if any squirts out then, or use a fuel pressure gauge that holds the peak value if doing it alone to see if the pressure goes up even a tiny bit, which it would if fuel is flowing back to the tank due to a stuck open fuel pressure regulator. If the pump is working at all, in this latter test, some fuel should come out, even if the fuel pressure regulator is bad.
Do you think that you can non-destructively (it's not rust seized on?) remove the return fuel rail from the pressure regulator output to see if fuel comes out when the key is first turned to run?
Without knowing more, I'd think that the fuel pump itself is more likely. If nothing else, because I see a lot more reports of those failing.
Just under 200,000 miles; I've owned her since '99.
The initial problem isn't exactly like the OP's, but similarities exist. It actually starts and runs, but not well.
It started with P0174 and then P0171 codes and the CEL. I checked for vacuum leaks and found none, spraying some throttle body cleaner around the various joints--no differences noted. I removed the MAF and gave it a good cleaning with CRC MAF cleaner which didn't change anything. I replaced the fuel filter and opened up the old one; the pleated element looked very clean and the new one didn't have an effect.
I got a bit hasty and jumped to replacing the upper and lower intake manifold o-rings--no difference. Cleaned the IAC and the VIS while the manifld was out. I swapped the fuel pump relay with a spare--no change--also checked the power at the inertia switch and it does the nominal battery voltage for 2 or 3 secs and then shuts down the power given no crankshaft position data.
In the course of working through the codes, I reset the lean codes and after a drive the P0300 Random Misfire set the CEL and the P0171 and P0174 were pending.
I ran into the same issues that others have mentioned with OBD2 live data on the '98 (and '97 apparently) in that all 4 fuel trims are pegged at -100% and won't move (both Bluedriver and Ancel BD310 devices, same data). I've just recently downloaded Forscan, but don't yet have a compatible transmitter.
I put a pressure gauge on the rail and got 0 or essentially 0 psi KOEO. I started her up and the pressure rose slowly, but got no higher than 27 psi. Similar to the OP, on different occassions I would get 0 psi with KOEO and with her running. I removed the valve from the Schrader and got the same 0 psi.
The last thing I have had time to do was to pull the vac line from the FPR and, while I had 0 on the fuel pressure gauge, the idle increased with the vac line pulled.
Most everything is original less the fuel pump relay; that was replaced a few years ago when she just stopped. New relay fixed that up. Plugs have been changed. As noted above: New fuel filter, new intake manifold gaskets, new EGR O-ring at the intake manifold port, new throttle body spacer to the manifold.
Thanks in advance for the advice.
