Ok guys quick question. What Ford vehicles interchange with our Sport Trac Fuel Pump? I want to get a higher flowing pump for the new motor but im trying to stay "intank". Also did Ford come out with different size push-lock fittings? Im also changing the stock hard line to steel braided. If they make different size fittings then I should be able to get a bigger size so I can run bigger lines right?? Let me now what yall think!!
BTW
I have stock fuel lines from the tank to the fenderwell, and so far during tuning my fuel injectors are running about 35% capacity ( 42lb) and there is no hint of fuel starvation. I have a highly modified 347 v8.
the fuel lines are probably not going to be a concern for a long time.
Thanks JTSmith!! The only reason I want to get that steel braided line is cause I can get it cheap and becuase I need to reroute the lines for the suspension. So they have to come out anyway. If I get that high flow pump will I need to run a regulator for that Carb? Do you have any recomendations on what fuel filter I should use? Should it be high flow as well?
The only reason you'd need this type pump is to maintain the high pressure required by the injectors.
If you are going to use a carb, your stock fuel system is more than adequate. Yes you'll need a different regulator for a carb. My guess is around 6-7 psi at the most.
The fuel injectors in your truck run at 60 psi
Now, I'm not sure you don't actually need a completely different style pump-designed for a carburetor system.
They make pumps specifically designed for carbs, as most only use around 8-10psi. If you run a pump designed for fuel injection, I wouldn't count on it lasting too long. Many fuel injected systems include a return line for the regulated fuel so it doesn't restrict the pump too much and kill it, and the ST fuel system has the regulator and return line in-tank. I don't know what type of engine you plan on running, but if you have a provision for a mechanical fuel pump, just use it along with an inline boost-a-pump to get the fuel from the tank (mechanicals prefer to be gravity fed from the tank). If not, you should be able to get away with your stock pump regulated (aftermarket regulator of course) for a while until it dies, and then grab a specially designed pump and regulator to match the flow rating you'll need (given your carburator size and jet settings).
