myf16
- July 22, 2012
- northern California
- 96 Explorer XLT 4WD
My 1996 XLT 4WD has only 28 psi fuel pressure and codes that it's too lean for the computer to compensate. The filter is fairly new and there's no vacuum leak, so it's time to replace the pump.
I have read about doing it the right way, lowering the fuel tank:
www.explorerforum.com
Then I saw this crude but effective alternative, cutting a hole in the floor directly above the fuel pump:
My XLT has 190k miles but is running strong. It looks beat up and worn out, so I don't mind adding one more mostly cosmetic insult. I can cover the hole afterwards with an aluminum sheeting screwed down. I have the metal fuel line tool, which I bought when I changed the fuel filter. Lowering the fuel tank looks much harder and with higher risk of failure than cutting the floor.
What advice do you veterans have for me?
Edit: I just discovered that I have a steel crossmember above the fuel pump, as someone mentioned in the comments to one of these writeups. So I will need to drop the tank. Ugh.
Fuel pump / Fuel tank - Tips and warnings
My '95 XLT , 2WD, recently died, luckily in my driveway. I had just changed a brake rotor and went to move the truck and it didnt start. Actually made me chuckle: Change brake rotor = kill truck. :scratch: ;) Obviously the two were not connected. So using all the great info from this site...
