Scotts96sploder
- February 10, 2019
- Jacksonville FL
- 96 Explorer 5.0 rwd
I looked, can’t find a good answer.
Problem: 96 5.0, crank no start, can’t hear the fuel pump.
I checked the fuse and swapped relays, checked power at the inertia switch thing, get a spike in run, ran 12v from the battery to the green and both the other (actually tried all the combos) and did not get the fuel pump to run. Checked resistance from there to the pump, all combos mega other than the two not ground wires around 7k. I also had someone crank and poked around at the plug to the pump and got a bunch of different voltages 12/6/5.
Assuming a bad pump but I would like to check power to the pump pigtail to be 100% certain before replacing the whole sending unit. Does anyone know which two pins are the power to the pump at the pump plug?
Once I know it’s the pump I was going to get the whole sending unit, that way I won’t have to go back in there again for hopefully another 25 years.
