ivldenis
- December 20, 2023
- Gyumri
- FE5 2012 Limited
I apologize, I am writing through a translator. FE5 2012 294 Lim+. Mileage 98,000 km. The problem first appeared two months ago. I'm starting to overtake. I press the gas pedal all the way, but it remains fully pressed. I started knocking on the pedal, it returned to its normal position. I replaced the gas pedal with a new one. Cleaned the throttle. And then two months later the problem repeated itself. I started driving, pressed the gas pedal to the floor, and it remained pressed. The pedal does not touch anything and does not cling to anything. I connected the OBD2 scanner - no errors. What could it be? Could the electrician be at fault? PCM?
