Okay. The reason people change their gears is because it compensates your overall gearing for when you change your tire size. When you change your tire size, your gearing will be higher or lower, in your case higher. The taller tires dont have to spin as far as your stock tires to go the same distance. But you loose torque and end up having to go faster for the same RPM's. Whew.
Next, if you have 4wd, you have gears in the front and in the rear. So if you change one, you change the other or else when you are in 4wd the transfer case will try to spin the same front and back and you will cause major damage.
Lastly, I have never personally done a limited slip. But I have heard that they are not that hard and is worth it.
In conclusion, if you get bigger tires, like 32's, you will really not like having 3.27's and you wont have jack for torque. Yes both have to be changed and a limited slip is not that hard and do it the same time as you do the gears. Oh yeah, it depends on what kind of driving you do to figure what gears to change to. With 32's, 4.10's would be a good match. If you go any bigger and really like being able to go super slow while off-roading, then I reccomend 4.56's.
Thats it. I am sick of typing and it is past my bedtime. If you are still confused . . . wait until tomorrow when I feel like typing again.
