Gen 1 dropped ttbs. | Ford Explorer Forums
Gen 1 dropped ttbs.
fordkid88
Madison Wisconsin
1993 Ford Explorer
OK guys I've searched for a bit now, and I can't find explorer specific ttbs. Now what I do see is a lot of ranger drop beams, and since I have a 93 ranger and 93 explorer and and the first half of the of both of the chassis appear to be the same, will ranger drop beams work for this.
Thank you so much, and these look a hell of a lot more burly than the DJMs, I think these in conjunction with the stock coil springs will give it the stance im looking for.
The chassis Tech beams are the only ones on the market for explorers, they are different than the ranger. DJM beams are wayyyyy better if you ever plan on doing air ride, they have more clearance and are made from DOM tube. But you have to swap clips on the explorer to use them and for all that its better just to do a toyota or mustang ii clip. For a static drop Chassis Tech beams work fine but they are expensive.
