Glass Soft Open/Close - How to Disable? | Ford Explorer Forums
tidji74
Missouri
2022 Limited 4WD
I suspect I accidentally enabled the feature in Forscan a while ago and now it appears to not close the windows completely.
When I try to reverse that to original value - there is no change.
Can that be a part of Global Open/Close "bundle?"
What is glass soft open/close?
It slows down before reaching top or bottom of its range while opening/closing a window.
Did you save the stock files before messing around on Forscan?
I only saved the "Profile" file... Never saved the module files. My bad.
I was able to download the .ab file from Motorcraft.
All the values in DDM (AB) and PDM (AB) indicate that the feature is disabled. But it still does its thing (slowing down regardless of settings.)
QUESTION: Do windows in your Explorers close with a slow-down, or they go all the way up at the same speed?
Since I rarely pay attention to the windows opening and closing, I just tried it on my Aviator and there is no "soft open/close" on the window.
Can Fordscan get into the Drivers and Passenger door modules? If you can each of those modules should have a window initialization option run that and it might fix your concern.
