How to disable factory alarm?
alakers
casper, wyo
'94 4WD
Well after a bit of a process I figured out how to make it work. There is a number of connectors back there, once I got the right one I had to leave the key on, then plug in the battery. Now I don't have keyless entry or an alarm, but I'm workin with a guy to get a new fob. Only problem is finding out enough about the alarm to work with it. I can't find much information, and I'm pretty sure it was installed by the dealer not the manufacturer. No idea what dealer it was originally sold at either !
So was something leaking, getting a component wet when it rained or what ??
Join the Elite Explorers for $20. Gets rid of the ads!
Explorer Forum has probably saved you that much already, and will continue to save you money as you learn how to diagnose fix problems yourself and learn which modifications work without having to experiment on your own. Elite Explorer members see practically no advertisements, no banner ads, no double underlined links, can add their own profile photo, upload photo attachments in all forums, and Media Gallery, create and save more private Conversations, and more. Join Today. Your support is greatly appreciated.
Currency
Bedford Indiana
94 XLT 4x4
Thinking it was just rain coming up from the tires. I know that side window in the back drivers side leaks but it's not really bad. It could have caused the problem, just need to tighten it up.
You should be able to go to your local BMV or DMV whatever it's called, I forget, and pay like $8 for a vehicle history report, just need the vin number and you don't have to own the vehicle. This should tell you pretty much everything about every owner including what city/dealer sold it. I think this route beats carfax :)
Hopefully it helps, as for my alarm. It's still unhooked and yes, it's been broken into since then but little to no damage was done and the only things missing were loose change, pocket knife, and a husky box cutter. I need to upgrade the rear window motors with newer model, none cable ones. :(
alakers
casper, wyo
'94 4WD
Well looks like in the next couple days I'll have keyless entry anyway...
Some dumbshit in class asked me if i was missing a set of keys.
O god I was pissed got in his face and all, seriously...je takes them, obviously not his to begin with.. and keeps them for a week and a half. ahh
That was a great 125 spent for a locksmith. Maybe I'll squirrel it out of him.
alakers
casper, wyo
'94 4WD
Damn kid returned my keys. all of them except my door/ignition key and key fob.
i drove to class, they were obviously on there. I wanna kick his ass !!!!
dato-svani
Georgia,Tbilisi
1997,Ford explorer
where car remote starter wire is located,i would like to disconnect it
dato-svani
Georgia,Tbilisi
1997,Ford explorer
i mean Ford explorer 1997;4 doors
dato-svani
Georgia,Tbilisi
1997,Ford explorer
How do you deactivate a 1996 ford explorer factory alarm?
beachbum78
Just for those of you like me trying to do this, on my '94 it is the 2 sets of white wire harnesses in front of the others behind the fixed part of the panel (yes that means you need really skinny hands). Of the 2 white connectors it is the most forward connector you have to disconnect, I had to disconnect both then re-connect the 8-pin (rear most connector).
thanks,
AJ
Thanks AJ. This totaly worked for me. It was a pain to get unpluged but It worked. Thank you!!
BMeinhart
Holiday, Fl
2002 Ford Explorer 8cyl
Hola,
I see this thread being old so there has to be a fix by now!?!
my 2001 or 2002 Ford explorer is going off at all hours. Pulled the horn fuse. Neighbors appreciated that. Grounded One of the three grey with purple stripe ( may not be the colors this was a while back) Yes three identical wires of the same color. Seemed to work for a little while now its doing it again. I have three outlets to my pats sys.
Question is which wire/s do I cut?
Pic
http://www.pinterest.com/pin/465981892666084763/
:roll:
TexasTurkey
1994 explorer
Man I hope this thread is still alive--I have a 94 explorer with a dealer installed system--it has several white plug-ins with about 27 wires--under the dash above the drivers left foot--I want to disable or remove it as it keeps me from starting my truck--will disconnecting the plug in the pass rear kill it?
94 green explore
Port Huron, MI
94 explorer, 4wd, MT, 4DR
Must be nice to do that. Here in MI you can only do a vehicle history on your own vehicle with proof on ownership and DMV will only go back 7 years. If the current owner has owned longer than that (7 yrs) then it will show who it was purchased from. But only if purchased withing 10 years.
Make the request thru the mail to Lansing, they can go back farther but it is $20 per name change and they will not inform you the possible cost before doing the look up. So it could get expensive quickly.
Currency
Bedford Indiana
94 XLT 4x4
I wish I could help you, sadly. I had spoken to some admins here and was ask not to share the information your requesting as it could be used by people other than the owner of the vehicle.
TexasTurkey
1994 explorer
It was super easy to get around the alarm and get the truck to start--I want to know how to get rid of the entire thing and good old ford only keeps records for 10 years-- I found a thread about a 97 model with a picture of his alarm which was just like mine with the plugs re-arranged--the quality of my dealer install was almost amateur but my real problem was as I had reasoned before the alarm went off which was a defective ignition switch and I already had the part and replaced it after disabling the alarm--I'll just pull plugs off the alarm now and see if my door locks and lights still work as the siren is disabled so I don't have to listen to it now
67Ragtop
Tustin, California
1994 Explorer Limited
Removed connector still will not start
Hello. 1994 Explorer Limited - My pats system will not allow the car to start. I first tried shorting the disarm wire to chassis ground per another site post - did not work. I found this thread and disconnected the 11 wire connector. Car still does not start. Starter does not make any noise. Any ideas? Battery and starter are good. The system will not disarm. I have the explorer 1994 electrical and vacuum troubleshooting manual. But I am not an electrician. Any ideas.
TexasTurkey
1994 explorer
On my 94 I really got no answers here but accidently found an answer about a model a year or 2 newer--I took the box out but lost the use of my automatic locks--to get mine to start I looked in a wiring diagram and found the colors of the wires going to my starting system red and maybe black I think but don't exactly remember--you likely have a mess of spliced taped connections like mine and you have to put the starter wire back together and likely the wire to the ignition since the alarms were not factory installed--I took out the entire alarm once the vehicle would start but did not want to reconnect the entire mass of wires that were cut and spliced so my electric locks no longer work but my truck starts--I just disconnected the 2 plugs on the alarm box --the tape the installer used was so nasty I didn't want to touch the mess--Ford did away with the instructions after 10 years and these alarms are JUNK
67Ragtop
Tustin, California
'94 explorer pats
Thank you. I'll need to sit down with the wiring diagrams and trace the wires so I can bypass the control module. I'll let you know how it goes. Thanks again.
sandansail
1998 ford explorer
i have a 98 ford explorer and need to dis arm the alarm cant start it alarm gos off all thetime i had to disconnect the battery and leave it at work need help
TexasTurkey
1994 explorer
The alarms were dealer installed with a connector ford put in and lots of cut and spliced wires--like my post above says I used a wiring diagram to find the colors of the wires going to the starter solenoid and the ignition and find where the alarm box wiring had been spliced into the circuits--then splice the original wires back together--then I unplugged the alarm box which was hanging above my left foot with tape--I lost the use of my electric locks but Got the use of my vehicle back--any thief willing to do all that to steal a truck should just get a job--on my truck the wires were 12 ga. red and black
steelynirvana
North Carolina
1993 Explorer
Did all first generation explorers come with an alarm? When I bought my 93 xlt I only got one key, the "credit card" one that came inside the owners manual. Ive never seen the anti theft light come on but have always wondered if it has one
TexasTurkey
1994 explorer
The alarms were DEALER INSTALLED--not factory--they came with wiring for an alarm in the harness but any alarm was installed at the dealership and much depended on the installer--they just cut into the factory wiring and spliced the alarm into existing circuits--mine was just laying up on the wiring harness and the splicing was just taped with real crappy black tape--BUT the alarm has a ford official sticker on it and fits the plugs to start it into the wiring for things like the electric locks and windows
D Disable A/C Stock 1991 - 1994 Explorers 4
ld50 First gen dome light disable switch install (front) Stock 1991 - 1994 Explorers 7
A disable auto hubs? possible? Stock 1991 - 1994 Explorers 8
R How do you disable the anti theft system on a 94 Explorer? Stock 1991 - 1994 Explorers 6
N Disable hubs altogether? Stock 1991 - 1994 Explorers 1
B autolamps or daytime running disable Stock 1991 - 1994 Explorers 21
D Wiring Aftermarket Head Units to Factory Amplifier Stock 1991 - 1994 Explorers 6
J Which year factory repair manual set? Stock 1991 - 1994 Explorers 7
Rhaegal94 '94 Explorer factory amp vs bypassing factory amp Stock 1991 - 1994 Explorers 5
HSlough Factory wire Looms Stock 1991 - 1994 Explorers 1
mgmgmg Factory CD Player Stock 1991 - 1994 Explorers 15
O Anyone Know Where To Get Factory Style Seatcovers For A Gray 92 WLT 4X4 Stock 1991 - 1994 Explorers 5
T How many miles out of your factory a4ld? Stock 1991 - 1994 Explorers 25
T Factory Radio Amplifier Stock 1991 - 1994 Explorers 10
NorwegianFord Size from factory? Stock 1991 - 1994 Explorers 2
S Factory Alignment Specs... Stock 1991 - 1994 Explorers 4
C Adding A/C to a factory non-a/c truck Stock 1991 - 1994 Explorers 13
W Factory paint colors? Stock 1991 - 1994 Explorers 4
D factory service manuals Stock 1991 - 1994 Explorers 5
4 Factory front mount tranny cooler? Stock 1991 - 1994 Explorers 5
I What are the biggest tires I can get on a factory Explorer? Stock 1991 - 1994 Explorers 3
C Increase Range of Factory Anti-theft Stock 1991 - 1994 Explorers 1
W Factory security. Stock 1991 - 1994 Explorers 2
mr cribb Dome light stays on/ factory radio sounds garbled Stock 1991 - 1994 Explorers 0
C 1991 4.0L factory oversize main OD Stock 1991 - 1994 Explorers 5
B "BAD" factory radio Stock 1991 - 1994 Explorers 4
P Factory Roof Rack Removal. Stock 1991 - 1994 Explorers 9
D factory radio upgrade Stock 1991 - 1994 Explorers 6
T Factory Sub Amp Wiring Stock 1991 - 1994 Explorers 16
N Factory Anti-Theft Problems Stock 1991 - 1994 Explorers 0
C FSM - Factory Service Manual request Stock 1991 - 1994 Explorers 10
T Factory Temp Gauge giving me fits Stock 1991 - 1994 Explorers 3
C '94 XLT Factory Keyless Entry Problem Stock 1991 - 1994 Explorers 0
safn1949 Factory Service Manuals Stock 1991 - 1994 Explorers 0
T Factory Trailer plug/ installing trailer wires Stock 1991 - 1994 Explorers 7
B Factory battery cables part # Stock 1991 - 1994 Explorers 8
H 1991 Explorer factory amp questions. Stock 1991 - 1994 Explorers 2
stev0n How do I know if I had factory alarm/keyless entry? Stock 1991 - 1994 Explorers 16
B How to find out what radio it had from factory? Stock 1991 - 1994 Explorers 16
Black Goblin replacing factory alarm with new one and need wireing diagram... Stock 1991 - 1994 Explorers 2
C Factory running board question. Stock 1991 - 1994 Explorers 4
J Factory manual 4x4???? Stock 1991 - 1994 Explorers 8
B Where to find factory Heat reflective Fabric Stock 1991 - 1994 Explorers 7
M Factory amp? Stock 1991 - 1994 Explorers 5
M 91 Factory Speakers... Replace with? Stock 1991 - 1994 Explorers 17
A where is the factory amplifier? Stock 1991 - 1994 Explorers 15
S Accessing Factory Sub Stock 1991 - 1994 Explorers 6
D Can I remove the factory crossbars? (roof Rack) Stock 1991 - 1994 Explorers 2
V removing factory amp Stock 1991 - 1994 Explorers 13
D 93' XLT Factory Trailer Wiring Not Working! Stock 1991 - 1994 Explorers 2
Similar threads
