Terkins
- November 14, 2017
- Location
- USA
- Charlottesville, VA
- 2000 Ex XLS; 4x4; OHV-6
(I had some trade-in value left so) I installed a new Interstate MTX-65 AGM battery last week. CCA 750; CA 935. I've taken several trips including going 'over-the-mountain' to Charlottesville since. All has seemed 'well' until last night. (My 3-yr-old lead acid battery was rated at 675 CCA.)
I also added an accessory plug-powered (3A), heated seat cushion. (To this item) I added an (red LED) on/off switch so it can be turned off easily when exiting. However, at one of my stops, I'd forgotten to turn it off. [Meanwhile both the new on/off switch (and a second, identical one powering my dashcam/etc. simultaneously) quit displaying their built-in (red) 'ON' LEDs? I tested them each: They were still cutting power on/off (each).]
When I went to try to open the drivers' door, it was locked. I could see the opposite door unlocked still (?) I tried my key fob several times...then my 'spare' key fob: Neither would pop the lock on the drivers' door lock! I tried both keys in the (drivers) door lock itself: Neither would turn/open the (drivers) door? I walked over to the passenger door, opening it, and activated the lock/unlock switch on the passenger door armrest. The driver's door lock popped open! I returned to the drivers side and switched off/unplugged the heated seat cushion. I tried locking the drivers door using the door switch: That switch worked. I then tried again to pop my door locks using the key fob: 'Nothing'; key-in-drivers-door-lock: (again) 'Immovable'. (The store was going to close so I locked the vehicle and left it be.)
When I returned, my key fob opened both front doors as usual.
I plugged the heated car seat into the top accessory plug and it began working fine.
(Both red 'ON' LEDs on both accessory plug lead switches were still non-illuminating, though power was being conducted through each to the respective accessories connected.)
(I'm beginning to fear that the electricity from the new, AGM battery is somehow 'foreign' to my 2000 Explorer? Is it supplying TOO MUCH CURRENT and 'playing (hidden electronic) games' with the electronics in my Explorer? (I've never experienced these kinds of behaviors before.)
