crunchie_frog
- June 19, 2010
- Johnson City, TN
- Multiple 99-00 5.0 AWD
Without the front drive shaft, smooth, no noticeable vibration. With the front drive shaft (I have tried 3 different drive shafts, one new, two rebuilt), and I get a grinding vibration type feel that gets worse when I take my foot off the accelerator or put in neutral. Transfer case is from a salvage yard but I have verified all 4 wheels are turning on jackstands and I cannot spin the tires on wet roads accelerating like I can when the front drive shaft is removed (2WD) so I am thinking the viscous coupling is okay. I am thinking it may be a bearing in the front differential or in the transfer case. I have not been able to detect any horizonal movement in the bearings but I cannot tell for certain. I am planning on draining the transfer case in clean pan and see if I can see any metal and I also am going to double check for any horizontal movement of the front drive shaft at both ends.
Any ideas about what could cause the grinding vibration feel?
Thanks,
Thanks,
