- August 3, 2000
- NORTH IDAHO, 7B
- B2 "Slightly" Modified
- Callsign
- FOURTEN
I know man I was just poking fun
the EB suspension as you call it is a radius arm solid axle with drag link, the axles used C wedges and bushings to connect to the radius arms. The axle was suspended using steel coils.
You see there are ALOT more ways to get a solid axle under your rig then simply just leafs or EB coils, there are 3,4, and 5 links.
there are ALOT of trucks on this site running the Ford style coil sprung solid axle, they used a similar setup in full size broncos, f-150's F-250's, vans, etc. the Early Bronco is just one of many.....it is a popular donor because the later model years had disc brakes and a low pinion dana 44, and the axle width is real close to a stock explorer front end.
Whew.
Whew.
