The Transmission was fine. The problem lied in my T-case. I was out wheeling when the truck popped out of 4x4, and into Neutral. After rocking the truck back and forth, it went into 2wd High. I was also tapping on the case at the same time. I ended up replacing the entire T-case, by myself. Not that difficult to do. The time involved was understanding how the T-case worked, and what could be the problem with it. Rebuilding cost 2-3 times as much as buying a used one. At least around here it does.
The easiest way to see if it is your T-case is to remove the shift motor (5 mins), and try to manually move the shift rail by hand. It should move fairly easy, with little resistance at first, then moving effortlessly to the next position, till it "Clicks" into gear.
This could be or could not be your problem.
You mentioned it was "Bucking", that could be because it is in to high a gear for the rpms. This could be a Transmission problem in itself. I am just trying to help Eliminate the guess work, by suggesting the T-case. Shift motor removal is fast and easy.
