Sharon
- June 20, 2002
- MI
I'm Desperate Can Anyone Help?
Our 1998 Ford Explorer, 4.0 liter EFI SOHC, has been sitting for two weeks at the dealership with a blown engine that Ford will not repair even though we purchased the extended service plan and it is still under warranty ($4,350.00 minimum to replace engine.)
One week prior to the blow-up, the A/C system was repaired under warranty to the tune of $800.00 and then proceeded to not work again by the following Friday. While on the way to work on the next Monday the truck's temperature gauge light came on (no check engine light) and immediately the engine lost power. Luckily it was 5:00 am so losing power at 70 mph didn't kill my husband. The dealership didn't know what went first the head gasket or the thermostat. Upon removing the thermostat they discovered it was clogged with this dark gray thick residue that is soft enough to smush between two fingers, but the radiator cap is clean.
Service tech said someone had put "stop leak or something" in the cooling system and they would not cover it. The thermostat has already been replaced a year 1/2 ago because it was not working and the system was flushed and refilled at a "blue oval dealer." A different service manager friend of ours said the antifreeze has broken down and the additives clogged the thermostat. The truck has had all necessary maintenance performed on schedule and has been into the dealer over 17 times for various problems.
Has anyone ever seen this before and do you know of any information that I can access to prove to Ford this is their problem and they need to fix it? Any help would be appreciated! Thanks
1998, Ford, Explorer
4.0 liter EFI SOHC
Automatic transmission
70,000 miles
Fuel Injection
ABS brakes
P/S - A/C - Cruise control
Rack and pinion steering
4.0 liter EFI SOHC
70,000 miles
Fuel Injection
ABS brakes
