PCTechman
- December 16, 2005
- Central Islip, New York
- 1991 Explorer 4X4 EB
After driving for a while the headlights go on and off, and back on. Seems like it's a defective relay or switch. I don't find a short anywhere, and the lights do not go off when going over bumps. After a few minutes the lights go off/on when parked in the driveway, without the engine running, so I think it's a relay/switch problem rather than a short. All the connectors & connections check out OK. The headlight switch was overheating and it melted the modular plug where it plugs into the harness. I changed both the headlight switch & modular plug. Now it takes a little longer before the headlights cut out, so I guess I fixed part of the problem. The headlight switch seems to get hot, though it hasn't melted the modular plug. I bought a replacement headlight relay (gray), but I can't seem to find where it's located. After another member told me where to look, I located 3 of the same type of relays under the fusebox under the hood, they are green, tan and black, though. I'm going to remove each of those relays to see if the headlights go off when removed. When headlights are on they are both equally bright, not dim. Any other idea's? Anyone know of a different relay location or which of the 3 colors the gray one should replace? Maybe there's another relay/switch somewhere?
