roveer
- September 28, 2006
- Morristown, NJ
- 2013 Explorer XLT
My 2006 Eddie Bauer recently had a radiator failure and an overheating event. I had the dealer put in an aftermarket radiator and that problem is solved.
Now I seem to have a problem when I turn on the vent I get full heat. If i turn on the AC full blast I sometimes get cold out of the left console vent and hot air out of the right console vent. This is with Dual mode turned OFF. It seems after a period of time I get cold air out of both vents. I believe if I just turn on the vent I get heat from both vents.
Is it possible this was due to the overheating event? I had turned on the heat full blast to try and keep the radiator temp down.
Ideas? A bad thermostat? Dreaded blend door?
Thanks,
Roveer
Thanks,
Roveer
