MidnightRebel07
- March 6, 2010
- Pittsburgh, Pa.
- 2003 Explorer Sport Trac
Yep, those are the correct shackles that you want.
The squeek could be a couple of things...
1. swaybar bushings need greased
2. swaybar endlinks are worn out and loose
3. rear leafspring isolation pads are worn out or missing
These are the first things to check for squeaks over bumps, it doesn't rule out the shocks but they have to be really worn or dead to do that.
Have someone stand in the bed and jump while you listen to each corner for squeaks then go and push down on the frontend repeatedly to histen for the front.
My shackles have no center brace and. They are fine
That probably means that you're leaf springs are shot out then. May wanna try doin the aal now then, the longer ones not the short style.
