- February 13, 1999
- Location
- Tampa, FL
- Chief GPS'um and Still Lost Native Texan
- '99 EB 4x4 "Herc" RIP
'99 4wd SOHC w/5R55E. The old tranny blew on me last weekend. When it let go, the engine went up to 5,500 rpm or so for a few seconds before I figured out that I was essentially in neutral. I put the tranny in neutral and coasted to a stop.
At that time I tried to shift into different gears while the engine was running, but doing so confirmed that I lost all gears. Tranny fluid was all over the underside of the Explorer so I blew the tranny good (but that's okay because I still have Herc's tranny to swap in). The engine was idling fine while I was beside the road and trying to get back into gear; it ran at least a couple of additional minutes after the tranny let go, so I know it's okay. I turned the key off shutting the engine down, and got a tow home.
Now I have tried to start the engine and get nothing - zilch. Turning the key to the "start" position does absolutely nothing; it's like I'm not turning it at all. No click, no starter noise, no anything. The electrics are on because I can turn the radio on etc, but the engine is not trying to start.
Can anyone tell me what is wrong?
