Mutineer
- August 23, 2005
- Location
- Ardmore, AL
- Ardmore, AL
- 1997 Explorer XLT 4X4
- Callsign
- FLOYD
OK so heres what Im doing, and I want to keep this a separate thread from my SAS thread, in case someone else has this issue...
I am using the following:
Stock PS pump
Steering gear from 1978 Ford F250 H.D. 2WD
Stock PS Pressure Hose
3/8" High pressure rubber hose for return(due to lack of correct PS hoses for this combo)
OK heres the deal.
The Steering gear has 2 fittings, a 3/8" and a 1/2".
The Pressure hose fits perfectly in the 1/2" fitting (thread depth and everythng) and I have a nipple installed in the 3/8" fitting for the return hose.
Heres what happened:
cranked truck and everything was fine untill I touched the steering wheel, then the wheels jerked over to the right all the way and the pressure line blew out it's side and sprayed my whole driveway with PS fluid.
After cleanup, I was able to figure out where it blew.
My camera was soaked with fluid so I was not able to get pictures, should be able to get some tonight.
Has anyone seen this before?
Could it be that I hooked it up backwards?
Im to the point where I think I need to ask before I move forward.
Stock PS pump
OK heres the deal.
