bronchole
Driveway flexing!
- May 13, 2009
- Los Angeles, CA
- 1997 Monsterneer
- Callsign
- KI6MCO
Help selecting 12” sub-woofer and 5 channel amp
So I made a not-so-stealth 12" sub box a while back and I am ready to do a slight upgrade to it. I need to put the 12” sub-woofer I have been running back in to its original enclosure and install it in my son’s car so I am researching the replacement for it. I think this would make a great step up: Rockford Fosgate R1S4-12. While I am playing with things I wanted to install a 5 channel amp to really get things rocking. Here is the one I was thinking of using: Rockford Fosgate R600X5 5 channel amp. It looks to have just the right output for the sub-woofer and should drive my Infinity door speakers to their potential. I just hope the amp is slim enough to mount under the back seat because I would like to mount a sine power inverter where the current amp is.
What do you all think?
Dan
Specs:
Amplifier Rated Power :
(RMS Continuous Power): 50 Watts x 4 + 200 Watts x 1 @ 4-Ohms
75 Watts x 4 + 300 Watts x 1 @ 2-Ohms
Sub-Woofer Power Handling (4 ohm single voice coil):
(Watts RMS): 200 Watts RMS
400 Watts Max
Infinity door speakers (4 ohm):
RMS Power Range (Watts) 2-60
Peak Power Handling (Watts) 180
Dan
Specs:
400 Watts Max
