HELP-starter | Ford Explorer Forums
HELP-starter
SERGE13
Mogilev Belarus
2000explorer4.0l xlt
Does not work the starter. It must be removed for repair. How to unscrew the top bolt? He is fixed and the place is very small. Means watered-no effekta.Kak unscrew this bolt?
To remove the top bolt I go at it from the front of the vehicle. Use a series of 6"-12" extensions, and a swivel socket. Feed the extensions a couple at a time until you can place the socket on the bolt, and remove it.
Thank you gmanpaint. You say that the upper bolt need to unscrew the front of the vehicle. For this we need to raise the car for a frame-up? What is a series of 6 "-12 "? It's head size in inches?
You can reach the top starter bolt from the front of the vehicle. You reach the starter bolt by using a long extension made with a few shorter extensions put together, by sliding the extensions in from the front end of the vehicle. The starter bolt is a 13mm.
Not sure if I can elaborate any better than that. If someone else thinks they can, please help me out here :)
I think Gmanpaint was saying connect an assortment of these together.
images
in various 6 to 12" lengths.
Thanks Friends! Now I understand. I think that now I do it.
Yours faithfully .
