bobflood
- May 27, 2010
- Powder Springs, GA
- 1997 Eddie Bauer V8 2WD
'97 5.0 2WD EB; 285K miles: I have finally decided to fix the coolant leak in my TC cover. I have access to a lift, air tools, etc so thought my buddy and I could do it. Job has gone OK until now. We have the TC cover off - were dropping the oil pan per shop manual. however - we are STUCK.
How do you get the oil pan out from underneath the engine so you can clean up the surfaces and put in a new gasket. We have loosened up the exhaust so it is not in the way, and it is 2WD so no front drive stuff, but there appears to be no way to work the pan back far enough to clear the steering rack. At most, we can drop it about an inch or so in the front, and the back won't come close to dropping far enough to slide back below the tranny.
What are we doing wrong and can anyone offer some advise. This is the best auto forum around, so I know there is a lot of wisdom out there. Thanks in advance for your help!!
