treynon
- September 1, 2004
- Huntington Beach
- 97 XLT
I just need the front brakes done on my 97explorer xlt rwd and im sick of paying 300+ dollars to get it done by some named business with questionable ethics. So if I get this right I take off the wheels, then calipers, then spindle (cradle?) then before putting the calipers back on I take out the slider pins (any tricks?) and greese them slide them back in, then I remove pads and replace with grease on the back of the new ones.
then I clamp the brake line and skrew out the bleeder skrew some and then let fluid come out then take off clamp, skrew back bleeder skrew and take off hose clamp (is that the right order?). Then I put the cradle? back on the spindle and tighten down then do I put the new pads on?
then bleeding I pull master cylinder cap off open one bleeder at a time to let air out then close the two fronts off and test brakes until the brake firmness is acheived.
Im new to brake jobs im just so sick of being jacked are there any pictures I can look at or anything so I can have more a visual? Am I saying this correctly I really want to get this down to save big $$$.
Thanks
Thanks
