help with herculiner preparation | Ford Explorer Forums
BoatsRcool
Greenville SC (Home) Clemson SC (School)
GMC Yukon 4x4
well i used that dupont bed liner spray awhile back, and its just not tough enough. sometimes it will chip, peel etc.
so i was a Northern Hardware yesterday and usually the herculiner 1 gallon, with brush and rollers is like $100 but it was on sale for $70 so i got it.
Now do you think I can just roll the herculiner on right over the dupont stuff.. or do i have to take it off, i really dont want to take it off. and how many layers of herc do i use.
I'd say you probably oculd just roll it over, but I'd really recommend taking it off so that you could be assured of a good bond with the metal.
For the bed fo the trucks they recommend two coats, most people use 3-4. For my bumper I used about 5 or 6 just ot be sure :).
from what I've heard...
For the most effective application of Herculiner, you should wash the hootus thoroughly to remove any excess grease and grime that may have accumulated.
The average hootus can be sufficiently coated in one application. However, some hootus' will require several coats to build and form thus yeilding and acceptable thickness.
Even though Herculiner has a lifetime warranty, it may be beneficial to re-coat the hootus annually. This is especially recommended if your hootus is high milage or is used in commercial applications.
...Oh God
:smoke:
What are you coating with Herc? You probably mentioned it in your post, but I missed it. I would think that you should strip the old stuff off, since it's flaking or whatever. Then just roll on the Herculiner over the metal.
well, i got around to doing it this weekend. new problem. i coated the rockers with mineral spirits, to get the dupont crap off, but it wont come off. so i guess ill just have to roll the herc over it once it dries again.
also, i opened my herc gallon just to look at it, and it looked like a can of dip.. ???
And pee BEFORE you start working with the Herc... Bad things happen when nature calls and Herculiner answers... :smoke:
Warning: Always remain fully clothed when handling Herculiner!
On a side note Some guy on the DiRT (Dodge Ram) mailing list said he was going to Herculine his bed and another member told him not to get any on his hootus. I can't believe that everyone knows about that and it started on this great board. Oh well.:rolleyes:
Oh yeah for best adhesion i would sand down the dupont stuff or at least all the loose parts.
