Help with TT Shackle lift and fitting tires | Page 2 | Ford Explorer Forums
Thanks a lot. Is yours 2wd or 4wd or does that matter? I'm a 2wd.
Mine is 4WD. I am not sure if it matters, but I would double check the Advanced Auto Parts website and do a search on your model to confirm.
No problem at all;
Rancho RS5000 Series Shock - Part No RS5185 and Part No RS5374
Paid $218.36 for all four delivered to the door from Advanced Auto Parts
And also I just order an add a leaf kit it comes with 2. I only need that 1 pair correct? Or do I need to get another pair of 2?
The AAL (Add a Leaf) part number EXP13120 come with two leafs, one for each side; you only need one kit/pair.
Unless its a sport, then you need to change the entire rear spring pack over to 4 door leaves. The 2 door used a mono leaf setup.
