HeLP! | Ford Explorer Forums
HeLP!
1993 sport 4x4
when i put my truck in 4x4 when i turn the wheels either way and drive it binds so bad it stops the truck , straiht is fine but the more i turn the faster the truck stops and once in a while it sounds like the hubs chatteralmost like tryin to engage..i just did bearigs and ball joints tie rods brakes wtf is going on??
Woot Search a bit - hint:its 4wd related (that pretty much gives it all away)
In! Thanks for the chance ... :p: (what do I win?)
You're not trying to drive in 4wd on dry pave are you?
ok so the chatter coming from the hubs is sometimes followed by a large clunk then the noises stop for a bit... as for the chatter itself almost sounds like a grinding and when i turn right it's' the left hub and when i turn left it's the right hub 4wd engages and disengages by the push of a button with no probs still. But the noise comes and goes.... any ideas? (i know it has to do with the 4wd) could it be the hubs or cv's (ujoints) it's a rather serious sounding noise..lol
