SuperKirby
- June 23, 2012
- Central MN
- 1993 Explorer XLT
To rewind, when I got my Ex, I was told it needed an LIM gasket. Further research and I found out I needed head gaskets (bubbles in overflow tank, unexplained coolant loss.) Bought a gasket set and because I got me Ex cheap and had some extra money, I went ahead and bought a new set of heads to minimize the time I was out of a vehicle. Did everything, had some questions, but after everything was said and done it started up and ran with no lights. I figured I did ok, though still was loosing some coolant and a few bubbles in the tank. Didn't think much of it.
Well, here I am again and the thing has started running quite poorly the last couple weeks. Started looking around and the first thing I did was check my plugs. Lo and behold the first plug I pulled out was shot, full of crusted on white, hard nastiness. That was #4 cylinder. #5 looked fine. #6 was also pretty bad. Cleaned up those plugs and put them back in. Ran better but still not good. Oh, and I'm getting a pretty steady stream of bubbles in my overflow tank.
So it looks like after 2 years the head gasket job that I did that I thought I might have messed up has finally given up the ghost. If I had to guess I would say the mistake happened in either the cleaning and prep of the block surface or in that I bought the cheap fel-pro gasket set. Most likely both.
I'm going to order up parts this weekend, probably all from Rock Auto. Some questions -
- First, is it better to order the head gasket kit? I'm looking at the Victor Reinz set with all the necessary gaskets.
-For LIM gaskets, I'm confused on 1 piece vs. 2 piece, or a 1 piece from I think it was a 97? If someone could tell me specifically what gasket is best I would appreciate it. This isn't something I want to do a third time.
-What's the best method to clean and prep the block and head surfaces? I haven't overheated at all and the heads are only 2 years old so plan to reuse them. I saw somewhere a few people have had good results with Easy Off oven cleaner and a scotch brite pad.
While I'm tearing into it, and to make this job and future work easier, I'm going to pull out the dead AC system and change over to a non-AC blower box. Anybody have one floating around they'd be willing to part with? And since I need to change my spark plugs, I may as well change my wires. Plan to go with NGK platinum plugs and NGK wires. Then, because I've always been curious about it, I'm going to get the high intensity ignition coil from Rock Auto and try that out. Worst case it's junk and I'll put the old one back in, but I figure for $35 I might as well try it.
