Dennis1188
- May 13, 2009
- West Lafayette, Indiana
- 96 Sport, 4.0 OHV
96 Sport 4.0 OHV
Decided to change my own power steering pump after dealer quoted me a price of 450.
Did it myself for fewer than 65 bucks.
Let me just say right from the start that this was very easy and if I can do this, anyone can and should plus you will save big bucks.
I will explain how I changed the pump and I will also explain how I flushed out the system… an option you may want to consider.
This was done on a 96 Sport so this may not work on other model years and more importantly; I am a newbie with very little mechanical experience so please keep this in mind.
You will need to take the belt off the power steering pump pulley and jack up the car.
I decided to take the wheels off so I can have easy access to everything.
I also took off the rubber shield in the wheel well, it is only held on by several plastic clips.
Now I have easy access to the bottom of the steering pump. It has two hoses connected to it.
The top hose with the two nuts is the high-pressure line and I only disconnected it from the outer nut.
The lower hose is the return line and I used pliers to crimp the metal tabs while I slide the clamp down without pulling off the hose just yet.
IMPORTANT:
I pulled the lower hose off with my left hand and with my right hand quickly covered the hole with the plastic cap that comes with the new steering pump. This helps prevent a really big mess of leaking power steering fluid. The high pressure line did not leak much fluid.
You can see in this photo the little black cap.
Another view
Remove four bolts (circled in red) from the top of the compressor.
You may also want to pry out this plastic clip (see end of screwdriver) holding a bunch of wires.
OK
Move ac compressor out of the way the best you can.
Next you will remove three bolts (circled in red).
Now you can carefully wiggle out power steering pump along with the bracket and this is what you should have.
Now it is time to take off the pulley and you will need a special tool for this job. Autozone gave me one to use and DID NOT CHARGE ME. All I had to do was leave a 35 dollar deposit which they gave me back when I returned the tool.
The kit is very, very easy to use and in this photo I have the puller already in place, now all I need is a little muscle along with a couple of wrenches.
Pulley came right off... real easy and in less than three minutes.
Now you can remove the old pump from the mounting bracket by taking off three bolts (circled in red).
NOTE:
Transfer the little black cap shown in this photo from the old pump to the new pump. This will prevent any leaks from the return line opening.
Here is a photo with the pulley on the new pump. I changed over to a different type of screw that is included with the kit and pressed on the pulley onto the new pump, very easy.
JUST REMEMBER: Mount the new pump on the mounting bracket before pressing on the pulley.
OK
That’s about all there is to this job, real easy.
Wiggle the new pump with the mounting bracket back on the engine.
Install the three bolts to hold the bracket.
Install the four bolts for the compressor.
Connect any loose wires and clips and put the serpentine belt back on.
Now all you have left are the two lines, the high-pressure line and the return line.
I decided to wrap a small amount of Teflon tape on the high-pressure line before screwing it into place and that seems to have worked out for me as I do not have any leaks.
Now for the return line hose.
Option One:
With the return hose in my left hand I used my right hand to remove the cap over the drain plug and quickly inserted the return hose.
With a pair of pliers squeeze that little metal clip and raise it into place.
Fill the reservoir with power steering fluid.
Have a helper start the truck and slowly turn the wheel from side to side while you monitor the fluid level in the reservoir.
Do this for about five minutes.
Option Two:
I wanted to flush out the entire system so this is what I did.
First: Keep that little black plastic cap in place on the new pump to prevent fluid from draining out the bottom of the pump.
Now the return hose drops down very conveniently in front of the truck.
I took a pair of vise grips and ever so slightly pinched the end of the return line. When the engine is started, fluid will flow out of this line and I wanted to reduce that flow so that is why I pinched the line. You may come up with a better way but the point is to slow the flow down just a little.
I placed the return line inside a 5-gallon bucket.
I was very lucky and had several helpers. One started the truck up and slowly turned the steering wheel from side to side.
Another monitored the bucket to let me know when the fluid turned clear.
And I continuously filled the reservoir with fresh fluid.
Use a funnel... it really helps.
Also, have several bottles of new power steering fluid ready to go... caps off and close to you.
After four quarts the return line was filling the bucket up with clear fluid.
I turned off the engine and positioned the return hose close to the pump.
Later that day I sprayed that part of the engine compartment with two cans of cleaner and hosed it all down... nice and clean.
So there you have it… the power steering noise is all gone and I saved enough money to do my shocks next.
Have A Nice Day
IMPORTANT:
Another view
OK
NOTE:
OK
Option One:
Option Two:
Have A Nice Day
