just wondering how many miles you guys see on a 4.0L before you have to worry about timing chains going bad???
about 100K on old style (< 2001 model).
never have to worry on >= 2001 model, unless you start to hear the death rattle.
I replaced the lower oil pan gasket in my 2002 XLT to fix a leak. I found some pieces of white plastic in the pan. The car has no history of any major engine work performed (Carfax, dealer records, Ford STAR report). Mileage is 92,000. No noises, it starts and runs perfectly. Should I be concerned?
Keep changing the oil and filter regularly, at least every 5 on mineral and 10 on full synthetic. And the 6 quarts of the transmission oil / filter every 30K to 50K.
Hi Exproblems,
in your case i suspect a sprocket bolt may have let go, not worn out guides, that will happen without warning on startup due to the extra force on the chain then. (the slow speed is not liked as it pulls and pushes on the chain). there is nothing you can do to predict that.
neither my mechanic nor the Ford dealership.
