How many miles on your 3RD GEN! orig. tranny????
IPcamper
2002 Mercury Mountaineer
180,000 on mine, with about 18,000 miles of towing a 2500lb trailer. Dealer serviced the trans at 60K and at 120K. Still shifts fine. I am planning on having the trans serviced again after the first of the year.
webwzrd
St Cloud, MN
'02 Limited v8-4x
I post 4 years ago on the thread when I had 158k. Now I'm up to 184K and still going strong. However it's up for sale, so the next report will have to come from the new owner.
Tyleryac
NJ
2005 Ford Explorer XLT
My original went at 92k miles
JoshMcMadMac
Waynesboro, PA
140k miles and 12 years before I replaced it. It was exhibiting minor symptoms when I bought it at 85k miles, and managed to keep it happy until this past summer. I might have been able to get away with just replacing parts but for the $1600 cost of a complete, updated transmission it was worth the peace of mind to swap the whole thing out.
tman1257
yankton, sd
2003 Explorer
120k and the only work was a fluid flush. The tech said that it was probably the best shifting trans he has worked on. I don't pull a trailer but I will say if I need to pass somebody on the highway, 3rd gets a workout lol.
mitch28
Burlington,MA
'03 XLT
16500 original trans (no lie!)
kevin512
St. Paul, Minneota
Last month I sold my '02 Explorer with 206,xxx miles. Transmission was never serviced, not even a fluid change (not that I recommend that).
tybogit
Fairfield, OH
04 explorer xlt 4.0
04 with 180k on factory trans. still wheelin..
caspian65
Apex, NC
2002 Explorer
'02 EB 4x4, bought new, was daily driven up until about 18 months ago. 218k miles, original engine/trans never been out or repaired. Only service ever done to engine was replace t-stat/housing, spark plugs at 100k intervals, spark plug wires at 150k and then the normal stuff like oil/oil filter, air filter, etc...
We have had to replace some suspension components, nothing major.
Timing chain guides are worn and engine is rattly on startup, but quiets down and still runs/shifts fine.
RedJeep
Ohio
03XLT 4.6 & 15 Unlimited
03 4.6 purchased new. 110,000 mi. Trans oil change at 60,000. Has trailer tow package and has been used a lot for cargo trailer long distance and a 2500 lb boat 5 long distance pulls. Never had any problems other than rear gears when new and under warranty. Replaced brakes at 90,000. Probably best car I have owned ever. :) :)
ConCave
Little Silver, NJ
2004 Explorer XLT Sport
'04 XLT Sport - Bought new
212,000 on original engine/tranny
Never beat it. Did lots of 2000 lb hauling with it over long hilly trips
Still going strong
One Tranny flush around 100k
Was advised not to touch it again at this age
Great truck
Only major replacements were two front wheel bearings
And a rear diff whine under original warranty
Whining again and now with a ClunknChunk when warm
(It seems odd to me why it would have to roll a few miles to get that pretty loud noise)
Anyway- Got a junkyard diff with 83k $450 -1 year warranty and a set of Detroit rebuilt
CV's $145 off of EBay going in this weekend.
chris8428
New Mexico
2005 Ford Explorer
I have a 2005 XLT with 77800 miles and no issues to speak of with the exception of a hard shift once in awhile when I go from drive into reverse. The fluid was flushed at 60,000 miles but other than that no service. I drive 100 and twenty miles a day with all of that being highway miles.
Hitchhikingmike
Dallas, Texas
'02 XLS
'02 XLS V6 Explorer. 120k miles. haven't had to take the transmission out yet.
-all wheel bearings
-front ball joints twice
-AC compressor now seized
-blend door actuator
-valave cover gasket twice
-rear left window regulator
-oil filter mount gasket
-passenger window regulator just went out- stuck a C-clamp on the track for now until i can get around to replacing the regulator assembly.
-5R55W started slipping at 100k, replace external piston/servos with the modified type with o-rings on the shafts and fine ever since.
Just wanted to throw out the transmission fix I did here:
http://www.fordservoboretransmissionfixsolution.com
/\fix working good for 20k miles now.
Argentimage
MI
2005 Limited
158K And second that Mobil 1----but--- when you stop firmly, there is a delay then surge slam.
Also happens - that is step on gas and no forward movement for a few seconds then slam bam.
Is this the $400 servo valve or?
Louisortiznj
Elizabeth no
2000 ford ranger
junked the explorer at 255 no rebuild all original...
MyMounty
NJ
2005 Mercury Mountaineer
05 Mountaineer 4.6 - 131k and still going strong.
bobbaloo38
fl
02 xlt
Just broke 200k. Though im always the slowest off the light half of my miles have been pulling a 6x12 cargo trailer. In fact i wore that one out and bought a bigger one with a 5k axle. At 190k. I moved a forklift 50miles pretty sure i exceeded the towing limit. Was told by a transmission tech not to change the fuild.
wbw11
Augusta, GA / Carmel, IN
2004 Ford Explorer V8 XLT
I have just over 148,000 miles on mine.
I'm not the first owner, but as far as I know it still has the original transmission.
In the past year I had to put in a brand new engine and a brand new rear differential.
motc777
Longview, TX
2004 Mountaineer
Well, question. Does it still qualify as the original transmission if it was recently rebuilt?
If so, mine went 165K miles and then had to have it serviced.
bigfordlover2
TN.
2004 Ford Explorer XLT 4X
I have 199.790 miles on my tranny and have never had the fluid replaced or filter changed. It might go out tomorrow but I can't complain if it does. I do not know why everyone is having so many problems unless it is because they change their fluid.
I posted this last year and now i have 225,212 miles on my tranny. I still have not had any problems and i still have not changed the fluid or filter. I still say if you change your fluid you are going to have problems.
94Eddie How many miles on original 3rd Gen Tranny? Stock 2002 - 2005 Explorers 81
S 4.6L V8 - Typically how many miles before timing chain replacement? Stock 2002 - 2005 Explorers 17
K How many miles on your 3ND GEN EX? Stock 2002 - 2005 Explorers 17
L How many miles on the timing chains typically 4.0L Stock 2002 - 2005 Explorers 36
C High Mileage 4.6 motors. How many miles do you currently have? Stock 2002 - 2005 Explorers 4
B How many miles with fully synthetic? Stock 2002 - 2005 Explorers 12
1 How many miles before i should do my brakes? What brand to use? Stock 2002 - 2005 Explorers 7
D How many miles from stock tires Stock 2002 - 2005 Explorers 16
B How many miles will an explorer go for? Stock 2002 - 2005 Explorers 108
A To many questions!! Stock 2002 - 2005 Explorers 12
A Oil pooling between heads (and many other issues) Stock 2002 - 2005 Explorers 13
A No Start after many parts replaced... Stock 2002 - 2005 Explorers 4
B How many O2 sensors on a 2002 Explorer XLT? Stock 2002 - 2005 Explorers 1
F How many quarts? Stock 2002 - 2005 Explorers 6
F How many Catalytic Converters Stock 2002 - 2005 Explorers 8
B How many different lift gate struts are there?? Stock 2002 - 2005 Explorers 7
L How many Ampers for the stock alternater? Stock 2002 - 2005 Explorers 4
W Why do I burn up so many transmitions? Stock 2002 - 2005 Explorers 14
C How many K on your explorer and what repairs recently Stock 2002 - 2005 Explorers 19
R How many Camshaft position sensor on 2002 V8? Stock 2002 - 2005 Explorers 2
Exproblems How many heat shield band straps does a 2005 V-6 Catalytic converter have around it? Stock 2002 - 2005 Explorers 0
C Bought a 2004 explorer (DIYing many issues lots of questions) Stock 2002 - 2005 Explorers 9
A 05 Explorer XLt RSC/Advance Trac Many Issues Stock 2002 - 2005 Explorers 4
S IAC Problem: How many RPM's does your vehicle IDLE at? Stock 2002 - 2005 Explorers 32
N How many Quarts ? Stock 2002 - 2005 Explorers 1
P how many bellhousing bolts Stock 2002 - 2005 Explorers 2
C How many different auto transmissions did Ford, Lincoln, Mercury use? Stock 2002 - 2005 Explorers 0
B How many happy 3rd gen owners do we have? Stock 2002 - 2005 Explorers 21
M 2002 4.6L Explorer with rough idle/many codes Stock 2002 - 2005 Explorers 3
L How many Cats on a late model 2004 Explorer 4.0L? Stock 2002 - 2005 Explorers 3
S '02 V6 Explorer with Many Electrical Problems Stock 2002 - 2005 Explorers 21
R how many balance weights on front drive shaft? Stock 2002 - 2005 Explorers 0
R Running Rough. Many CEL Codes Stock 2002 - 2005 Explorers 2
W 2002 XLS too many wheel bearing failures. Stock 2002 - 2005 Explorers 4
Y How many axles does an 02 Explorer have? Stock 2002 - 2005 Explorers 14
A 2003 Explorer need tire(s) How many?? Stock 2002 - 2005 Explorers 2
C Why are there so many rear diff bearing failures on the 2002-up Explorers? Stock 2002 - 2005 Explorers 36
M power steering fluid leak 225,000 Miles Stock 2002 - 2005 Explorers 1
08EddieCA Get what you pay for: front timing guide fail <11K miles Stock 2002 - 2005 Explorers 8
T 05 Explorer engine fail safe mode after driving 5-7 miles Stock 2002 - 2005 Explorers 7
B "05" XLT 230K miles ABS light on but with a kicker!! Stock 2002 - 2005 Explorers 2
H what to service at 185,000 miles ? Stock 2002 - 2005 Explorers 3
H 2004 XLT with original ATF 160,000 miles Stock 2002 - 2005 Explorers 3
M 2005 Explorer 211xxx Miles. left and right low beams wont turn on. Stock 2002 - 2005 Explorers 4
B 05 XLT high 209K miles Stock 2002 - 2005 Explorers 5
J Miles to E keeps changing Stock 2002 - 2005 Explorers 3
C 03 4.0 17x,xxx miles chain went? Stock 2002 - 2005 Explorers 19
M 2003 Limited v8 - Message Center Shows Oil Change Warning After Only 2k Miles Stock 2002 - 2005 Explorers 3
D Looking for a good Transmission guy in Northern California, Sacramento CA+-200 Miles. Stock 2002 - 2005 Explorers 1
C 2002 explorer transmission 170,000 miles Stock 2002 - 2005 Explorers 2
Similar threads
