how much lift do i have? | Ford Explorer Forums
ExporeRanger
Highland, Md
92 XLT
i've got a 92 explorer xlt 4x4..and i recently put on a lift, a small one that i made with a couple different types of lifts. does anybody have a measurement for the top of their rear and front wheel wells? for a first generation explorer 4x4..4dr..with 120k?
thanks a lot..just a measurement in inches would help so i could compare!..
thanks again
-chris
My truck left stock height years ago so I cant help, but I am curious about this lift you talk about... details?
I took measurments on 5 different first gens. All appeared stock all with 235/75r15. The measurment to the fender lip from the ground to directly above the hub varied between 32 5/8" and 31 5/8".
thanks.. and my lift ..is a 2in coil spacer up front and a warrior shackle lift set for the rear compiled with a procomp add a leaf lift
jim..i that the front or rear fender wells?
you have 2" of lift :)
I bet the back sits higher then the front
i just measured my rear wells..at the peak of height from the ground to them..and it was about 34.5 on both sides..and thats with a procomp add a leaf and a warrior shackle lift set..
yeah well the coil spacer is a supposed 2in lift spacer..and the rear was a 1.5 in warrior shackle and a 1.25in procomp add a leaf..it should be 2.75 in total..but then account sag and wutnot..
add a leafs do wear out and sag in time, so expect it to drop a bit.
A 2" spacer is pushing your alingment to the max, I am surprised it could be aligned to 0 degree + camber
is this a 4wd truck?
yup..4x4..and i just put the add a leafs in about a month ago..i hope they aint sagged too much yet..plus im sayin the leaf packs look dangerously flat..
explorer leafs are pretty darn flat, especially after 14+ years.
Sorry! It is the front fender.
yeha im seein that now..there not so bad lookin at some others..cool..o the front fender?..hmm..well i think reguardless i got about 2.5in atleast in the rear..still need to find sometime and get the front lift on.. : /...i got my cold air intake done last night tho took bout 20 minutes..awesome lil mod..sounds real good..breathes deeper..bout 130 bux or somthin off ebay
