Curtis
- November 15, 2001
- Orlando, FL
- 04 XLT 4x4
I've been wanting to get homelink for a while now so I wouldn't need a garage door opener on my visor. Here are the steps to add it to a 3rd gen.
My 04 has a moon roof and no rear air. So I watched eBay for a matching roof console but with the homelink option.
My original roof console looked like this
The one I found on ebay was tan in color, but I only wanted the black piece in the middle with the moonroof switch and homelink
To remove the moonroof and homelink, there are small torx screws holding them in.
2 holding the black section in, and 3 holding the homelink on to the black piece. In order to remove this black piece you will have to remove the homlink module first. Then it just swings out and you're left with
I screwed the homelink back on because I wanted to hook it up to a battery and program and test before I took my truck apart.
Programming instructions are here
http://www.homelink.com/training/train.taf
There is even a video to watch which makes it really easy to understand.
Once programmed, you can disconnect the power and it will still work once you get it installed.
At this point you have to remove your roof console. Its held in place with clips so just pull it straight down. I found it easier to start by the windshield then by the moonroof.
Once removed here is what you'll see
disconnect the interior lights and moonroof switch.
and remove the black section from the original and replace it with the homelink module.
Here is my original
Here it is with the homelink module added
I found a connector that wasn't connected to anything in the roof of the explorer. I'm thinking this was intended for homelink but the connector didn't match the one I bought from eBay. With a meter I tested it and it has power only with key on, and its part of the delayed accessory so it will work until you open your door after you remove the key.
--> I will add that from my research on Google, some manufacturers have homelink with power full time, and others have it with key on only. I kind of like the key on only feature although having one on your visor is like having power on all the time.
So I decided to cut this connector off, and solder on the connector that came with the homelink module. If you don't have an extra connector you'll have to wire in power and ground from another source. You may be able to get that in the roof console from the lights already but I didn't check for it.
Here is the matching connector soldered on with some heat shrink on it
Now just plug in your lights, moonroof switch and the new homelink module and snap the console back to the roof. The final product looks like this
The homelink module is still programmed from when I tested it before the install. Works great! Now I can put the craftsman garage door opener on my Buick's visor
Here is my original
