The Electrician
- February 4, 2011
- Makkah
- 2008 XLT 4WD V6
Hi ever one
Here are the photos of the mounts that I made to fix ARB Awning on 4th gen Explorer OEM Roof Rack
I fixed the Awning using 2 mounts
each mount consists of 2 pieces
one is made of 1/8" galvanized sheet and the small one is made of 2/8" steel sheet
a thread should be made in the small piece
they are overlapping on each other
and a head of a bolt should be inserted inside the awing rails
then you need to remove the back corner of the roof rack
remove the crossbar and crossbar mount
the small piece should be inserted in side the roof rack rail and then a bolt should fix the large piece to the thread within the small piece
this is the front mount
this is the rear mount
and voila
and that's all guys
and voila
and that's all guys
