  • We are aware of the issue with our internal search engine and we will be bringing it back online shortly. For now please use the Google search bar near the top of each page. Thanks, Rick
How To: Fix the Door Ajar Problem
stpierre
Laconia N.H.
2002 Explorer xlt V8
I will go out and do it now! What do you want me to look for? The light on or off?
stpierre
Laconia N.H.
Let me go out and start it up and paperclip the two.;)
BRB give me 5mins I will post the news A.S.A.P.
BigRondo
USMC 1371
Moderator Emeritus
Worcester, MA
2002 XLT V6 4x4
So you're telling me that when you disconnect the liftgate & liftgate glass switches, 1 at a time, the interior lights do not come on?
Then there is an issue with the wiring. Did you revisit the thinner black wire in the boot?
Since the pics aren't in this thread anymore for checking the wires, here's what I did:
I can't remember, but I believe I unwrapped the wires enough to gain access. When I have gone searching in there I had an idea of what wire I was looking for. It was the thinner black wire. I located the thinner black wire and gently tugged on that wire on the door side. The wire was pulled toward me and out of the harness. I then went inside the vehicle and gently tugged on the thinner black wire and was able to pull it inside the vehicle. I then spliced a length of wire to the 2 ends, completing the circuit. I then gently pulled the excess into the door.
Like I said before, when I was having the following symptoms, it turned out to be the thinner black wire that was broken:
The dome lights would stay on until the battery saver feature turned them off, the accessory delay wasn't working, the driver side puddle light didn't work, the keypad on the door would set off the alarm when I pressed it, the door ajar light would flash and beep at highway speeds, the radio would shut off as soon as I turned the key off, the alarm would beep twice when I armed it.
I recommend following the above steps with the thinner black wire.
stpierre
Laconia N.H.
No luck with the glass but the hatch will ding but the door ajar light stays on.
The light is ALLWAYS on I have to turn it off from the drimmer. I will post a pic of my door no tape at all 2hrs looking at 3 feet of thinner black wire. lol
stpierre
Laconia N.H.
I dont have....This going on.
the accessory delay wasn't working, the driver side puddle light didn't work, the keypad on the door would set off the alarm when I pressed it, , the radio would shut off as soon as I turned the key off,
BigRondo
USMC 1371
Moderator Emeritus
Worcester, MA
2002 XLT V6 4x4
I'm getting a Popsicle headache. :p:
PM me your email address and we can go from there.
I am determined to get to the bottom of this. I will not be defeated! :D
stpierre
Laconia N.H.
I like to think of myself good with this stuff most of the time but this one is KICKING MY ASS.:mad:
stpierre
Laconia N.H.
Ok BigRondo I'm off in a few so if you want to talk cell is goinig to be the best way. I sent you a pm with my info.
Thanks for the help.
stpierre
Laconia N.H.
Holy shit it’s working!!!!!!!..........
I think what happened is I took out all 6 of the switch’s to clean and lube all at the same time.
Well I switched the two back one’s for the hatch and glass and now all is fine…WOO HOO…:bounce:
As far as I know both where the same? :scratch:
BigRondo
USMC 1371
Moderator Emeritus
Worcester, MA
2002 XLT V6 4x4
Are you serious? :eek: That is awesome. :biggthump
Looks like I don't get my northbound road trip. :(
stpierre
Laconia N.H.
Oh sure I have lots to fix still come on up.
1. Wheel bearing.
2. Driver side seat belt light code 33
3. Dripping ATF from I have no clue why? Some times when I try to start it the starter just spins on the flywheel.
BigRondo
USMC 1371
Moderator Emeritus
Worcester, MA
2002 XLT V6 4x4
1. Wheel bearing.
The trip may still be on!! :):thumbsup:
joshua8378
manton, mi
Just fixed my black wire in the door today. Thanks for the info.
kukusnest
2004 explorer
Thanks for posting this fix on the broken black ground wire. It was exactly the case on the 04 explorer my daughter now drives. I know this potentially could have gotten expensive chasing down at a shop. All it cost me was a bit of time. The hardest part actually for me was trying to strip the wire while holding the boot out of the way - just a bit awkward for me. I chose to wire nut my splice.
I want to say I really appreciate all the great info here and for those of you that take that extra bit of time to post annotated pic w detailed instructions, much heartfelt thanks.
FordyFour
04 XLS
I will be tackling this repair tomorrow, as I'm at wits end with the beeping sound going off every 10 seconds from the door ajar sensor. Originally, it only made the noise at random times when I was making a turn with my signal on..very strange.
Now with this arctic freeze thats hit the northeast, I think it accelerated the problem.
If I find a broken wire and go to fix it, it looks like the 12 awg wire is the same as basic speaker wire? I have tons of that laying around. Can I just just that to fix whatever area is broken and twist it all together and slap some electric tape on it?
rickmert
medina ohio
2002 ford explorer
where on the doors can i find the door ajar switch i have a 2002 4.0l 4x4 4 door model and cannot locate the switches
bdf24
Hartford, WI
2004 XLT 4X4 4.0L Flex
LOL, I've been dealing with this for a couple of years now! I just turn the interior lights off every time before turning the ignition off. I think I'm gonna tackle this soon though. I'm getting tired of it. I'll wait for the weather to warm a bit though.
jmem87
Can someone upload the images of the instructions for this repair?
Thank you
RKelly2233
Rochester, NY
03 XLT 4-Door Sport
Alright Bigrondo, I’ve finally come around to asking for your assistance as you seem to be one of the most, if not the most knowledgeable on here- or if anyone else can help for that matter id be more than grateful. My 03 V6 XLT is currently having some symptoms that maybe you can help figure out. I’m 90% sure its the drivers door. First and foremost, its at a friend place and he’s trying to figure out the door ajar issue as well. It happened once before and I sprayed the heck out of it with wd-40 and it was fine for a year- maybe 2! Now its back.. I spent an hour toying with symptoms and came up with the following; After starting the truck, the door ajar light and interior lights stay on until I get to about 10 mph when the dome lights AND door ajar light goes off and stays off until I open the door again. I can only use my keypad intermittently. When swinging the door shut, it flashes like it gets power and shorts out and then gets power and shorts out again. But when closed, I can't use the pad like its not getting power. If I’m driving and I turn the dome lights to the off position it turns off the door ajar light as well if for some reason they don’t turn off... About a month ago my mechanic friend fixed a wire to the power windows in which, like my keypad currently, depending on the position of the door they would work. Might be in that same wire group??? A separate issue (maybe not?!?) is that over the past couple years when set in the automatic position my head lights don’t turn off for exactly 3 minutes- I timed it over a dozen times to be sure. I do NOT have the message center so I can't change the timing of the lights- I also have an Aviator and am familiar with changing that. I have LED tail lamps and had the turn signal fuse replaced at one point due to rapid flashing when signaling right (but not left).. Its just frustrating. I’m at 199600 I think, and I’m eager to start driving her again. I just had the exhaust replaced a week ago and I was ready to get back on the road with her until this. I drive about 60K a year and spread the miles between a few cars but wont get rid of this one! Any help, from you or someone else is appreciated.
E Door ajar switch fix Stock 2002 - 2005 Explorers 1
M How to find/fix door open switches (door ajar issue)? Stock 2002 - 2005 Explorers 11
R Making 20 second blend door fix stick Stock 2002 - 2005 Explorers 0
T Cheap Fix For Broken A/C Fresh Air Door Stock 2002 - 2005 Explorers 25
P blend door fix? Stock 2002 - 2005 Explorers 1
E 10 Second Temporary Fix for Blend Door Actuator Problem... Stock 2002 - 2005 Explorers 75
B Fix door handle Stock 2002 - 2005 Explorers 0
L Servo fix Stock 2002 - 2005 Explorers 4
D Surprise fix for my dead '02 XLS Stock 2002 - 2005 Explorers 7
D 2002 driver window stuck down, EASY fix Stock 2002 - 2005 Explorers 6
D 2002 driver window stuck down, EASY fix Stock 2002 - 2005 Explorers 0
M Cracked Sun Visor Fix-Metal Bracket Available Stock 2002 - 2005 Explorers 1
B Just needs timing chain tensioner easy fix Stock 2002 - 2005 Explorers 0
A A/C issue question. Drivers vents warmer...FIX = ADD FREON Stock 2002 - 2005 Explorers 1
M To Fix or Not to Fix Stock 2002 - 2005 Explorers 20
C Servo O-Ring Mod A Permanent Fix For 5R55? Stock 2002 - 2005 Explorers 39
W Is a New GEM the Fix? 2002 V8 Stock 2002 - 2005 Explorers 13
M Looks like I got a leak, any idea how to fix? Stock 2002 - 2005 Explorers 0
M Worth to fix? Stock 2002 - 2005 Explorers 7
M 2002 XLT Rattle Fix? Stock 2002 - 2005 Explorers 2
B Vent Selector Switch not working - Easy Fix!! Stock 2002 - 2005 Explorers 2
I Dash vents not working - cheap easy "quick fix" success!!! Stock 2002 - 2005 Explorers 2
G 5r55w servo fix only OD and intermediate new Stock 2002 - 2005 Explorers 0
M Remanufactured Transmission = $3,800 installed, fix or junk explorer? Stock 2002 - 2005 Explorers 18
A Slipping tranny fix? Stock 2002 - 2005 Explorers 4
J Servo bore fix Stock 2002 - 2005 Explorers 64
trucku Broken Shift Lever Bracket FIX! Stock 2002 - 2005 Explorers 2
4 Rust: To fix or not to fix Stock 2002 - 2005 Explorers 21
R 4.0 SOHC rear chain tensioner anyone fix one that did not leak? Stock 2002 - 2005 Explorers 8
L how do I fix it? Stock 2002 - 2005 Explorers 5
A Please help me fix my Poor Explorer:( Stock 2002 - 2005 Explorers 7
R which is easier for rear end fix Stock 2002 - 2005 Explorers 8
R ford rear end fix Stock 2002 - 2005 Explorers 3
M Hood Paint Chipping/Bubbling-Bug Guard or Plastidip fix? Stock 2002 - 2005 Explorers 1
R servo fix for explorer trans Stock 2002 - 2005 Explorers 12
S Gear shifting issues! Need advice on potential fix Stock 2002 - 2005 Explorers 3
A e brake adjust/fix Stock 2002 - 2005 Explorers 15
F Dorman thermostat housing o ring leak fix. Help!!! Stock 2002 - 2005 Explorers 5
B Coolant gush after deep snow--magic self fix? Stock 2002 - 2005 Explorers 1
P Still rough, nothing left to fix Stock 2002 - 2005 Explorers 17
B Do the oil pan gaskets leak on 2002 4.0, or will front main seal fix the oilyness Stock 2002 - 2005 Explorers 2
C servo bore transmission fix Stock 2002 - 2005 Explorers 8
C no heat issue fix Stock 2002 - 2005 Explorers 0
imp Re: Gen. 3 Cracked Panel Fix Stock 2002 - 2005 Explorers 0
E fix or sell? 02 4x4 4.6 V8 Eddie Bauer Expl Stock 2002 - 2005 Explorers 5
E Lucas Transmission Fix???? Stock 2002 - 2005 Explorers 1
R Replacing transmission pan filter and adding Lucas Oil Transmission Fix Stock 2002 - 2005 Explorers 1
U Rear diff noise - fix it or ignore it? Stock 2002 - 2005 Explorers 10
8 2005 Ford Explorer with SERIOUS problems, Ford Garage hasn't even been able to fix Stock 2002 - 2005 Explorers 15
J Keyless Entry Pad: New Fix Stock 2002 - 2005 Explorers 1
Similar threads
