I am losing clutch fluid and the engine doesn't rev with the gas pedal when starting. | Ford Explorer - Ford Ranger Forums - Serious Explorations
Carl Toutant
Coquitlam, BC
92 4.0L Pushrod
I have two major problems. I drive a 92 Ford Explorer 4.0 L Pushrod, I am losing clutch fluid and the engine doesn't rev with the gas pedal when starting and after 30 min. The second problem got worse and worse and now I had to limp home on the side of the highway. The engine seems to sputter and miss like it's not getting fuel. Usually to fix the problem I would turn the engine off, cruising or stopped, restart it and I wouldn't have a problem for another 10 minutes or so or if I came to a large hill. As far as losing clutch fluid, I lose a few drops a day, but sometimes it goes fast. I have lost over an ounce of fluid just pumping the clutch with the engine on, cardboard underneeth was clean. I am flabergasted as to where the fluid is going.
Cody Dick
Central PA
'94 xl
Maybe a fuel pump relay? That would be a cheap and easy fix if so.
Your clutch fluid is probably leaking out of the slave cylinder. I think this is a pretty common problem with the 5 speed. I think the seal in mine is going too. The problem is this isn't such an easy fix.. The slave is actually inside the transmission.
I don't know.. I'm pretty much guessing. Some things too look further into though.
BrooklynBay
Moderator & long time member.
Staff member
Moderator
Brooklyn, NY
88 89 93 95 96 Aerostars
nitro71
Spokane WA
The slave is on the drive shaft on the front of the tranny. If you have a bigger jack or a tranny jack and are mechanicaly inclined it wouldn't be to bad a job to replace it.
