I lost reverse gear after a valve body rebuild. | Ford Explorer - Ford Ranger Forums - Serious Explorations
dustymorris
salisbury, MO
94 xlt
ok, so I put the shift kit in my a4ld. Had tires blocked and e-brake on. Put the valve body back in. Made sure I could see up into the reverse servo sleeve and see the spot where the end of the shaft hits. Thought I was doing real good. Until I tried to back up for a test drive. No reverse. What have I done?
BrooklynBay
Moderator & long time member.
Staff member
Moderator
Brooklyn, NY
88 89 93 95 96 Aerostars
Welcome to this forum! I've renamed your thread, and moved it into the transmission section. The 95 Explorer has a 4R55E. My 95 Aerostar still uses the A4LD. Did you use a 1/4" drive In/Lb torque wrench on the valve body bolts?
1AJeremyD
Mass
95 XLT 4.0
Something doesn't sound like its aligned right or torqued down. I hate to say it but re-torquing everything to spec would definitely eliminate a lot.
