ExplorerMomof4
- February 26, 2010
- Born and raised in Oklahoma ~ My heart lives in the Rockies!
- 1993 XLT
Just replaced the following:
When I took it in I was having a hard time starting it. It would just turn over and then it would start just fine the second time I tried to start it.
~As of Today~
It is still having this problem and our mechanic said the fuel pump was not gaining pressure like it should. He told me to turn the key and let it sit there for a minute before actually starting it. I am doing this and it seems to help the issue.
I filled the tank with Premium gas at no ethanol station. I also poured in some STP fuel injector cleaner... a mile later my check engine light came on! Somebody please tell me I didn't do something to make that light come on. and yes my gas cap is screwed on correctly.
Also, when leaving the gas station the needle on my battery power indicator started jumping around and the car acted funny but was fine after I turned onto the street.
- Fuel pressure regulator
- Rear wiper motor
- Serpentine belt
- Upper radiator hose
- Lower radiator hose
- Evaporator core
- Accumulator
- Orifice tube
- Low pressure cut off switch
- Low side R134A adapter
- A/C leak fixed
~As of Today~
