Hey Guys,
This yellow wire you're talking about bypassing will work, but there is a better way.
This yellow wire coming from the GEM goes to the "Torque-on-Demand" or TOD solid state relay. This relay, when energized, allows power to flow to a heavy duty eletromagnetic clutch inside the trasfer case. The wire that feeds that transfer case clutch power from the TOD relay is a heavier (12-14)gauge brown colored wire. This is the right wire to switch because you won't need to "reset" the GEM by turning off the truck and on again, because you're not disabling the TOD relay, you're disabling the power to the electromagnetic clutch.
The best place to access this Brown wire is at connector C200 located under the driver's seat.
I also recommend using a standard 30 amp automotive relay to do the disconnecting because it is a fairly high current circuit.
I seem like an expert on this because I just finished swapping in a Control-Trac transfer case to my 98 V8 Explorer which of course, had that stupid AWD. Getting all the electronics to work was very educational!
