rjtrinity
- September 25, 2016
- TrinityCo, CA
- 2010 Exporer
I had a great story here of my new-to-me Explorer dying out in the woods and the work I've done to it up to now, but that post had gotten too long so I'm giving the condensed version now. Anyway, the current situation is that I installed a new coil pack (old one definitely bad - very big crack) and had a very nicely running Explorer. For a few minutes. Then on the test drive it coughed once and died. I had cleared the codes before the test drive, now after it died it has codes for all 3 coils. The fuse for the coil was blown (2nd time). Replaced the fuse and it started, but runs terribly. Codes for 2 and 6 misfire. The coil looks perfect and the ohm meter says it's within specs. That and that it ran nicely for a while makes me thing the coil is OK. The repeated fuse blowing makes me lean toward a short in the harness and with the coil looking/testing fine the misfires on 2/6 could also be a short in the harness. So what I'm wondering is: 1) Is there a common point where the wiring to the coil pack goes bad? And 2) Can somebody describe the path of the wiring between the coil pack and the PCM? (pretty direct through the harness to connector X of the PCM, or via the fuseblock or...) Any other suggestions? Thanks in advance... -rj
