sphoto
- July 15, 2011
- SHINGLEHOUSE, PA
- 1995 AEROSTAR 4.0 AWD 6CY
I have a 1995 4wd 4.0 6 cyl. Aerostar. Over the past several months my coolant level has been going down on a regular basis. I can't see any obvious leaks and there are no puddles on the ground. I did run a bottle of 'Stopleak" through the radiator just for the heck of it but no change in loss of coolant. Any thoughts? Could this be a head gasket and if so, is there an easy fix to this without spending thousands of dollars?
So far this summer we have replaced Power Steering pump, rack and pinion, Air Conditioning compressor, front brakes, and I have a broken front spring that I need to replace.
