Interior Dome Lights Not Working | Page 4 | Ford Explorer Forums
Thank you
Welcome to the Forum Rachel.:wave:
I found this thread using the Forum's 'Search' feature (upper right) and merged yours with it.
You said you checked the fuses. Are you referring to both #4 and #12? There are 2 fuses that come into play with the interior lights. #12 is for the 'Courtesy Lamps" that come on when the door is opened. #4 is for the "'Demand Lamps" so they turn on when the switches are pushed. I would suspect fuse #12. If that fuse is good then it could be a micro relay as one member reported. http://www.explorerforum.com/forums...-dome-lights-not-working.328973/#post-3097791
