Is there anyway to make the AC blow harder. | Ford Explorer Forums
IB Pimpin
I had a Kia rental car and the AC blew WAY harder than my Explorer. Is there an upgrded blower motor or something I can get?
are you running it on max ac??mine blows plenty of air .you should see a large difference between normal and max and you should hear the exchange door closing.
Yes I use Max AC. It just doesn't blow very hard. The air makes lots of noise though. Could there be an obstruction somewhere?
Does most of the air come out of the defrost vents even when its on panel? Then you have a vacuum leak most commonly related to the lines going to the globe under the pass side wheel well
Also there is no filter for the hvac so if you live in a dusty area the condenser and internals could build up obstructions.
the vents can be opened and closed too. make sure they are open .they got slides on the sides of them to open and close each vent .
